chassis dyno
Posted 12 October 2006 - 03:16
6-7 years ago I spent some time researching chassis dynos for asm inspections with a possibility of using it for diagnostic work also.
Now the interest is bubbling again... the dynapac 4000 upgradeable to 4wd sounds interesting
Allthough I have no experience in it, I think there would be a small swell of just curiosity seekers to begin generating interest in it and then aggressively learning the info necessary to offer tuning ... especially with people changing thier own components and building packages that make proven power.
Not to mention the portability to go to track days and the sort
My question is what experience do people here have in different chassis dynos and thier pro's and con's
the dynapack seems head and shoulders above the competition when it come to convienience and repeatiblity of runs
It almost seems to be the the only sensible choice and other dyno's in that class obsolete
what are the drawbacks of this system
thanks
Posted 12 October 2006 - 17:36
Safety wise, I think I'd be more comfortable with a dyna pack unit. Hard for me to really relax on those rollers, especially with a FWD car.
As far as 'accuracy' goes, I think any dyno is as good as the guy operating it, maybe less so. Others here, like McGuire, have far more experience and are more intelligent then I, so look for input from them.
I have heard the sales pitches (in terms of accuracy) from both the dyna pack and the roller guys; none of them convinced me of the merits of one over the other. Good luck with it, hope you have fun with the thing.
Posted 12 October 2006 - 22:38
Posted 13 October 2006 - 00:45
we went thru the emmision testing phase neatly and efficiently without much effort required
but once we decided to do a horsepower run, the car was nervous on the rollers with the tires getting very hot and smoking. We resecured it and tried again, finnaly unimpressed we decided to forget about trying it. Ultimately the dream died with the hopes of running the vette at full song.
After reading about the dynapack it rekindled that desire to get into dynoloading a car for driveability and eventually performance loading
I've developed a reputation for fixing the unfixables and see alot of cars from other shops, but the idea of not having to drive a car above the speed limit on limited visiblity roads all the while looking at a data readout on a scanner and occationally a lab scope ... is to say the least inviting.
Posted 13 October 2006 - 00:47
Quote
When you run twin roller dynos do you use slave tires? You should.
i'm unfamiliar please expand
Posted 13 October 2006 - 00:48
Quote
please explain why you were unimpressed with either the roller or direct coupling
Posted 13 October 2006 - 00:52
Since every shop I've ever been in is tight on space, the portability is really useful from an economic standpoint.
My next choices would Dynodymamics and Mustang. The dynojet is of much more limited use.
Posted 13 October 2006 - 01:30
Potential for improvement in any chassis dyno installation: the engine cooling/fan setup. If you can devise an accurate and consistent mechanism for controlling the airflow at the front of the car you can go a long way toward producing more real and useful numbers... especially on all the cars running around these days with the great big air/air intercoolers hung on the front.
Posted 13 October 2006 - 02:31
This forces the tire belt into reverse curvature on both rollers. This severely weakens the tire. As you point out, overheating the tire is also common, this again will weaken it.
Our SOP is to use slave tires on twin rollers, there again, this is the first place I've worked with a twin roller dyno, most places I've worked have a single 2m dia roller, which is better for noise work, but not much good for full throttle runs.
The hub mounted dyno sounds better and better.
Posted 14 October 2006 - 18:16
From what I've heard, Dynapack is kind of a Rototest "light", cheaper but with less features. Both systems are hub mounted, hydraulic and portable but Rototest also have a model called "Dynamic" which uses AC motors instead of hydraulics.
