W9 engine - 2977cc, 526bhp
206 replies to this topic
#201 Greg Locock
Posted 06 October 2007 - 22:06
Moon Tricky - no, the 30% number I gave is a different 30% to the number you were trying to work out.
#202 Moon Tricky
Moon Tricky
  • 318 posts
Posted 08 October 2007 - 10:12
Quote
The number I worked out was 50%.
#203 Powersteer
Powersteer
  • 2,460 posts
Posted 25 October 2007 - 03:50
Quote
Originally posted by Engineguy
Looks really nice tucked down so low into that sports car. The firing order would be the same as a boxer six? As a low engine package, it reminds me of Formula one when it became a sort of engineering trend to bring down center of gravity with the wide angle vee 10 like Renaults 111 degree(or 109). Probably with the crank mounted so low it might have an even lower center of gravity than a boxer while using a much simpler crank, maintaining a shorter engine length. I'm not clear on its balance though. I'm still facinated by a 120 degree vee 12 and have always been.
#204 Moon Tricky
Moon Tricky
  • 318 posts
Posted 30 October 2007 - 12:15
a 120° V12 would be quite a beast. You'd have to have each crank pin 60° ahead of the last, instead of a straight-6 style crank, otherwise you'd get two firing events at once. The crank might be a bit stronger, with more overlap of one crank pin with the next, although would you need a balancing shaft?
A 144° V10 would also work.
#205 hydra
hydra
  • 417 posts
Posted 29 May 2008 - 22:44
What the world really needs, IMHO at least, is a flat-8 , short-stroke version of the LSx 5.0L , 500-600bhp depending on emissions, 7500rpm redline, 140kg all in a relatively compact package...
#206 Greg Locock
Posted 30 May 2008 - 13:05
That'd be a hard engine to love. It'd sound like a 4 banger, oi tink.
#207 hydra
hydra
  • 417 posts
Posted 30 May 2008 - 13:27
Quote
That's only with a flat-plane crankshaft with shared journals and double firing intervals. Not very appealing at all... Proper flat-8s should sound like a flat-plane V8, but without the vibration nastiness (if the proper crank configuration is selected)
Check out this video for a marvelous demonstration of what a flat-8 sounds like:
