F1 idle speed ?
Posted 13 October 2007 - 11:59
Anyone know for sure? The other chaps says 7,000rpm because he heard Martin Brundle say it on TV.
Posted 13 October 2007 - 17:39
Posted 13 October 2007 - 19:13
Posted 13 October 2007 - 20:14
Current Indycar engines redline at 10,300 RPM and idle at 3000 RPM, if that helps any. I would think F1 idle would be higher than this.
Posted 13 October 2007 - 23:36
Originally posted by phantom II
Mike the Bikes 250cc 6 cylinder Honda stalled at 12 000, he broke it in a 14 000 and it revved to 26 000.
Two stroke or four stroke?
Posted 14 October 2007 - 11:43
Phil Irving once said that a motorcycle company was running the tacho off the wrong timing gear to make it read double, he said that they did this to confuse the opposition. I wonder if he was refering to Honda?Originally posted by phantom II
Posted 14 October 2007 - 18:31
Source of information: Red Bull demonstration team running Scott Speeds 2006 car this summer.
Posted 14 October 2007 - 18:46
Honda's 250cc 6 cylinder (a four stroke with four valves per cylinder) reved to about 18,000. In 1967 Honda made a short stroke version that may have reved somewhat higher, but no where near 26,000. Honda made a 50cc twin that reved to 22,500 and a 125cc 5 cylinder that reved to 20,500. WPTPosted by phantom II
Posted 15 October 2007 - 04:48
This is correct.
Honda's recent road going CBR250RR revs to 20,000 but idles quite happily just above 1000. Two strokes in fact dont rev as high, they just sound like they do, an example being (again) Honda's CR250 motocross bike that produces its 54hp at around 6000 rpm. But of course 2 strokes have twice as many bangs.
Posted 15 October 2007 - 04:51
Originally posted by Bill Sherwood
On Youtube - yes, the paragon of accuracy - someone wrote that the idle speed of an F1 engine was 7,000rpm. AFAIK they're closer to 2,500rpm.
I wonder if they are given a false higher idle to keep them in a cleaner engine range? (on cam).
Posted 15 October 2007 - 06:34
I imagine with such low rotation inertia the idle is incredibly 'fragile' and so they probably idle them a bit faster than they would normally to make sure the slightest interuption didn't stop them.
I still reckon they could go as slow as the 2,000's, but breath on it and it'd stop.
Posted 15 October 2007 - 09:06
Posted 15 October 2007 - 12:00
Originally posted by shaun979
I recall reading something about minimum engine speed at Monaco and it wasn't too far away from that number.
I recall hearing during one of the telecasts (probably from Brundle) saying they dropped to 5000rpm for Loew's. I'm sorta sure that that was during last year's telecast, not this year's.
edit: Should have google'd first. In http://www.f1complet.../view/4219/365/ Mario Theissen says "The hairpin at the Grand Hotel is the only corner all year when engine speeds dip below 5,000 rpm."
Posted 15 October 2007 - 13:53
Originally posted by scarbs
BMW have published their idle as 4000 rpm....
Thanks, a definite answer.
Posted 31 October 2007 - 17:06
" Idle speed control of a F1 racing engine"
R. De Filippia, R. Scattolini, (Toyota Motorsport GmbH, Dipartimento di Elettronica e Informazione, Politecnico di Milano Piazza Leonardo da Vinci)
The paper is about idle speed control of Toyota F1 2003 car.
Best Regards
Orkun OZENER
Posted 31 October 2007 - 23:52
Originally posted by Orkun Ă–ZENER
I think you could find more detailed information about idle speed of a formula 1 car at that paper (pdf format)
Best Regards
Orkun OZENER
Thanks - A quick search did not reveal a link to download it?
Can you perhaps help a little more?;)
Posted 02 November 2007 - 09:21
Posted 02 November 2007 - 10:36
Posted 02 November 2007 - 15:19
Posted 02 November 2007 - 18:36
Posted 25 November 2007 - 11:24
Think 5000 must be on track as some point, Brundle did mention that Mclaren have system that when the car is stationary cuts out some of the cylinders to keep the heat levels down. Therefore can remain station for long periods of time.
Does anyone have anymore information on this system?
Mr_London
Posted 25 November 2007 - 15:11
Idle of around 4,000 sounds about right.
Posted 25 November 2007 - 19:39
Mclaren have a system that when the car is stationary cuts out some of the cylinders to keep the heat levels down.
As of the year 2000 the Cadillac Northstar 4.6 L V8 had just such a system.
"Another feature of the Northstar engines is a "limp home" mode that allows the engine to continue running if all the coolant is lost. If the PCM senses an overheating condition, it temporarily disables up to half of the cylinders. This pumps enough air though the engine to keep temperatures from getting hot enough to cause any damage. Even so, GM says the vehicle should not be driven more than 50 miles in the limp-home mode."
Posted 26 November 2007 - 13:23
Would this also be similar to the 'safe mode' that WRC cars sometimes switch to when they have problems?Originally posted by 12.9:1
