Why we think this is a '64 Shelby Team Car:
There were 3 ’64 team cars
CM/4/64 had the modified nose with bottom radiator opening and ’63 style tail section. Raced by Richie Ginther #92 at Riverside in ’64 and by Ronnie Bucknum #195 at Laguna Seca
CM/5/64 had the modified nose and flat spoiler rear bodywork with Cortina taillights. The nose was damaged in practice at Riverside and replaced with an unmodified unpainted nose for the race. It was repaired for Laguna Seca.
Raced by Bob Bondurant #93 at Riverside and #96 at Laguna Seca.
CM/6/64 had the modified nose and flat spoiler rear bodywork with Cortina taillights.
At Riverside it had a broad white area painted on the nose coming out of the stripe / roundel.
Raced by Parnelli Jones #94 at Riverside and #98 at Laguna Seca. It crashed at Laguna Seca and was badly burnt, bodywork was destroyed.
These 3 cars all had a unique frame modification. Fabricated perforated panels were bolted into the frame above the transaxle to make it easier to remove it. This frame has these unique pieces.
Although the previous owner had some updates done to the brakes, shocks, engine, exhaust, and rear uprights, the original parts were retained and are appropriate.
Original Tach with Shelby logo inside is included with the car.
Original engine with front mounted tach drive, webers, Shelby style heat shield, Shelby style bundle of snakes exhaust also came with the car.
We also have a unique Hayden Transcooler oil cooler that appears to match one installed on the Bondurant car at Laguna Seca. Shelby mechanic Frank Lance confirms that is the type used by Shelby.
At Laguna Seca all 3 team cars got full width roll bars installed during the weekend. There are ground off spots on this frame and cut outs in the rear aluminum panel where this roll bar would have been.
