Honda F2 Motor 1966
47 replies to this topic
#1 DavidLayton
DavidLayton
  • 35 posts
Posted 06 December 2018 - 16:31
I used a generic description of the motor as its official title RE302E may be confused with the 1968 F1 car.
The Japanese model company Ebbro has recently released a very lovely 1/20 scale kit of the Brabham BT 18 Honda F2 from 1966.  The kit does not include or show the ignition or the injection lines where they go into the metering unit for the injector or whatever Honda used in lieu of a rotating distributor.  The engine, like the S800 motor, did not have a typical distributor.  There are additional fuel pump lines I would like to trace as well. It appears that the coolant plumbing is included.
To my knowledge, there is the one complete Brabham Honda in the Honda collection.* This car was sent to Honda after the 1966 season.  The on-line photos are either showing the car closed in the museum or the exhaust side which does not show the ignition/injection source points.   There is a second motor, a cut-away motor in the collection but the on-line photos of it are of the right exhaust side with no lines or wires attached.
* Brabham ran two cars.  After the 1966 season F2 went to the 1.6 liter formula and Honda left on a high note.  (If you see a video of the car, it was a very high note)  The second factory team car was recently for sale with a Lotus Twin Cam in.  Other BT18's were sold to customers.  I assume in 1966, these would have likely used Cosworth FCA or BRM P80's.
Considering Honda's overwhelming success in 1966 F2, I am surprised not much can be found on this motor.  BTW, this motor is very different from that which was used in the BT16 in 1965.
Edited by DavidLayton, 06 December 2018 - 16:35.
#2 RogerFrench
RogerFrench
  • 688 posts
Posted 06 December 2018 - 16:58
I don't know about this engine but the S800 had a very normal distributor mounted horizontally at the forward end of the camcover and driven by the inlet cam shaft.
#3 PZR
PZR
  • 145 posts
Posted 06 December 2018 - 17:48
RA302E, no?
The Japanese mags and books (sorry to be obvious) are pretty good at showing the nitty gritty details on this kind of thing. I'll see what I can find in my collection...
#4 PZR
PZR
  • 145 posts
Posted 06 December 2018 - 18:10
This is the cutaway RA302E in the Honda Collection Hall:
(Image: 'Morio')
#5 MarkBisset
MarkBisset
  • 1,022 posts
Posted 06 December 2018 - 20:50
David,
I wrote a short article several years ago about the Brabham Hondas but i struggled to find engine 'nitty gritty' too- interested to see what pops up
Mark
https://primotipo.co...brabham-hondas/
#6 ray b
ray b
  • 2,973 posts
Posted 07 December 2018 - 04:38
WHAT ARE THE PAIRED LARGE BOLTS ?
about the middle going up at an angle above between the ext ports
#7 Ray Bell
  • 82,315 posts
Posted 07 December 2018 - 06:29
It must have had a bunch of compression to justify that size of starter motor!
A lovely little engine, there's not much size in that clutch.
#8 Pat Clarke
Pat Clarke
  • 3,033 posts
Posted 07 December 2018 - 07:20
I seem to recall this engine used torsion bar valve springs. The bolts would possibly be the 'stops' for these bars.
Pat
#9 Stephen W
  • 15,965 posts
Posted 07 December 2018 - 09:30
The F2 engine had nothing to do with the S800 unit.
#10 Cirrus
Cirrus
  • 1,759 posts
Posted 07 December 2018 - 10:28
For some reason I can't post pictures even though they appear fine in previews.
This is a shot of the early Honda F2 engine being installed at MRD
Here's another one
and here's the later, much neater engine
#11 Tim Murray
  • 24,929 posts
Posted 07 December 2018 - 11:18
Alan, the problems you’re having embedding images in posts are because you’re trying to embed them from non-secure sites - those whose URLs start with ‘http:’. Secure sites have URLs which start with ‘https:’. The forum software was changed in June - see this explanatory thread in the Website Feedback forum:
Autosport forums are now fully HTTPS
#12 PZR
PZR
  • 145 posts
Posted 07 December 2018 - 12:00
Honda showed one of the cars at the Tokyo Motor Show in November 1966.
Some press coverage in period Japanese mags (Auto Sport and Motor Fan):
Apologies for the low quality.
#13 PZR
PZR
  • 145 posts
Posted 07 December 2018 - 12:41
To clarify, the 1965 season engine was the 'RA300E' and the 1966 season engine was the 'RA302E'
RA300E:
4cyl DOHC,16 valve, 996cc.
72.0mm bore x 61.2mm stroke.
10.5:1 compression, 20.4m/sec average piston speed.
135hp @ 10,000rpm.
Weight 145kg.
RA302E:
4cyl DOHC, 16 valve, 993cc
78.0mm bore x 52.0mm stroke.
10.5:1 compression, 19.06m/sec average piston speed.
150hp @ 11,000rpm.
Weight 145kg.
#14 PZR
PZR
  • 145 posts
Posted 07 December 2018 - 13:44
'Auto Sport Historic' magazine used a small, uncredited, cutaway to illustrate the RA302E in their excellent 'Honda S800 Racers' magazine/book 'Mook' in 2011 (ISBN978-4-7796-1205-3).
I'm sure I've seen a similar cutaway in another Japanese publication, but I can't find it now.
#15 Allen Brown
  • 5,568 posts
Posted 07 December 2018 - 15:24
As far as I can see, only four Brabhams were ever equipped with these engines:
Brabham BT16 F2-11-65 - raced by Jack Brabham in 1965.  Unknown after 1965.
Brabham BT18 F2-18-66 - raced by Jack Brabham in 1966, up to Rouen in July, then sold to Kevin Murphy in Ireland for 1967 (without the Honda engine of course)
Brabham BT18 F2-19-66 - raced by Denny Hulme in 1966, up to Le Mans-Bugatti in September, then by Chris Irwin in three late-season races.  Presumably the Honda museum BT18 that was at Goodwood in 2005.
Brabham BT21 F2-20-66 - raced by Jack Brabham from Karlskoga in August 1966 onwards, then sold to John Kendall for F3 in 1967 (again, without the Honda engine).
#16 Fatgadget
Fatgadget
  • 6,983 posts
Posted 07 December 2018 - 16:05
Umm..Could have used it as a generator and additional traction motor  too!
#17 StanBarrett2
StanBarrett2
  • 1,021 posts
Posted 07 December 2018 - 16:20
Pat
Yes, looks like they are the end caps for the torsion bar housings...............just wonder how that all worked ?
Edited by StanBarrett2, 07 December 2018 - 16:21.
#18 RogerFrench
RogerFrench
  • 688 posts
Posted 07 December 2018 - 16:42
I know, I was responding to the original post.
#19 Ray Bell
  • 82,315 posts
Posted 07 December 2018 - 20:57
The torsion bar valve return system always had me intrigued...
What a shame air pressure came along, maybe someone else would have done this?
#20 DavidLayton
DavidLayton
  • 35 posts
Posted 07 December 2018 - 23:44
Interesting shot of the show car with the sparkplug wires going forward.  This 1966 race car, the ignition wires go back aside the fuel metering unit. This is Denny's car at Pau. Note the silencer. Assume this was needed outside of race times. You can also see the spark wires going straight back in the You Tube Video of the engine being started.honda-big-exhaust.jpg
Edited by DavidLayton, 08 December 2018 - 16:12.
#21 Stephen W
  • 15,965 posts
Posted 08 December 2018 - 08:16
Wasn't the engine installed in the Brabham mule chassis for testing before it went into the BT16?
#22 Paul Hamilton
Paul Hamilton
  • 441 posts
Posted 08 December 2018 - 11:26
Here's another one
Can anyone identify the gearbox fitted to the car shown in these photographs?
#23 Charlieman
Charlieman
  • 2,591 posts
Posted 08 December 2018 - 11:41
I think the perceived starter motor size is an optical effect because the diameter of the exhaust pipes is large too. Ditto for the cylinder head accessory overhang. Which means that the clutch diameter was even smaller than it looks.
#24 Charlieman
Charlieman
  • 2,591 posts
Posted 08 December 2018 - 12:01
According to David Layton's photo, the gearbox has a familiar large H label on it.
The engine sub-frame compared with that in PZR's photos suggests different generations of chassis.
#25 StanBarrett2
StanBarrett2
  • 1,021 posts
Posted 08 December 2018 - 12:26
According to a Hewland piece in Autosport...a Mk7
#26 Paul Hamilton
Paul Hamilton
  • 441 posts
Posted 08 December 2018 - 15:49
But the car in post #10 is not fitted with a Hewland and also has significant frame differences.
#27 PZR
PZR
  • 145 posts
Posted 08 December 2018 - 18:04
RA302E + transmission on Honda display stand at the Tokyo Motor Show, November 1966:
#28 DavidLayton
DavidLayton
  • 35 posts
Posted 08 December 2018 - 18:27
Well that explains the wrong direction of the ignition wires.  I am very curious as to the distributor that would be at the base of the rear of the block.  Interesting to note that this engine appears to be monochromatic as opposed to the metallic gray block and gold head components.  I hope to find photos of the operating car's motor and the clear photos from 1966.
#29 DavidLayton
DavidLayton
  • 35 posts
Posted 08 December 2018 - 18:38
In addition to the engine mysteries, I hope to find a good set of photos of an undressed BT18 F2 to map the fuel lines between the fuel tanks and the fuel pump.  I have the brake lines worked out.  Once I have the documentation worked out, I plan to do a build blog on building this kit.
This kit has 4 ancillary items on the frame on the left side of the motor beneath the intakes:  2 coils, Water Reserve Tank, Fuel Pump and what could be an oil filter attached to the frame with 4 hoses running through the fitting.  See this photo from an earlier post showing what appears to be the oil filter prominently:   http://www.historicf...amper/TNF11.jpg
Edited by DavidLayton, 08 December 2018 - 18:40.
#30 StanBarrett2
StanBarrett2
  • 1,021 posts
Posted 08 December 2018 - 19:34
Yes of course, I was a bit over enthuiastic posting, should have said ........ for the races they used Hewlands
#31 Roger Clark
Roger Clark
  • 7,570 posts
Posted 09 December 2018 - 10:09
It is usually said that the Cosworth DFV and FVA were first to adopt the narrow valve ange/ 4 valve per cylinder configuration. Others point out that the Weslake V12 was first, but did Honda beat both of them?
#32 PZR
PZR
  • 145 posts
Posted 09 December 2018 - 12:50
A couple more from the 1966 Tokyo Motor Show:
#33 DavidLayton
DavidLayton
  • 35 posts
Posted 09 December 2018 - 20:38
Good photo.  Shows 2 of the 4 injection lines going from the intakes down.  I suspect there is a valve panel on the metering pump similar to the Kugelfischer on a BMW 2002tii.  The Throttle linkage is the line arcing around the metering unit on the rear of the left cam.  As seen in the phot from Pau and if you see the YouTube video of the surviving car being started in the garage in Motegi, the ignition wires go directly back into the undefined.  On the video, the wires are aligned in a row rather than in a circle, which makes me wonder if there was a transistor board (it was the 60's) in lieu of a distributor.  These go into a covered area not seen in the Pau photo but past the metal clip in the Pau photo.
#34 Ray Bell
  • 82,315 posts
Posted 09 December 2018 - 20:49
Do we know the firing order, just out of interest's sake?
It must be either 1-3-4-2 or 1-2-4-3.
#35 rl1856
rl1856
  • 393 posts
Posted 09 December 2018 - 22:25
Wonder how a pair of these, bored out to 1.5L each, and joined with a common crank would have performed ?   All in a package scarcely bigger than the F2 chassis.  Certainly lighter and smaller then their V12 and Honda (later Hond-ola) package.....     Guess we will never know.
#36 StanBarrett2
StanBarrett2
  • 1,021 posts
Posted 09 December 2018 - 22:32
Honda hachi ache
#37 DavidLayton
DavidLayton
  • 35 posts
Posted 10 December 2018 - 04:03
Here is a bit of a 'money shot'  The 4 ignition wires appear to go into the block next to the coolant line.  I also see the 4 fuel lines going into the fuel pump similar to the BMW Kugelfischer on the lower right and I found the same part on the kit!  The throttle linkage is also very well displayed.  I found this on Facebook and it ties to a French site on Monthlery.  I can also trace the throttle line to the front pedal bulkhead, the use of black rubber brake lines and the tach cable going to the pick up on the front of the left cam which is a kit part.  Edit:  Subsequent review of BT18 details show that the throttle line connection was on top of the frame above the accelerator.  So I believe the throttle line went past the instrument panel and angled to the accelerator.  Wire in front bulkhead may be wire for Temp Gauge.
BT18-Honda-clear-Distributor-Shot-With-N
A picture of the model itself.
https://www.facebook...&type=3
Edited by DavidLayton, 27 January 2019 - 18:01.
#38 DavidLayton
DavidLayton
  • 35 posts
Posted 31 December 2018 - 01:57
Still Pondering where the 2 oil lines from the remote filter (on the frame to the left of the motor) that run to the forward right side of the motor or front.  The motor is a dry sump with the 2 pipes to the oil tank in the front located on the front right side of the motor running up the right side of the frame.  Based on the 1Liter F2 news letter  produced by Keith Whittle, there is a cut-away left side view that shows the oil pump with 3 pick ups along the bottom going forward but the two hose connections are not marked.
There are also pictures that indicate that the throttle ran along the left side of the frame.  Usually, the throttle cable goes back along the right side, if the intake was on the other side, cross behind the driver.  However, the photo in a Honda Collection book shows the line going past the cockpit on the left.  So was there some sort of pivot device on the accelerator that allowed the cable to go in front of the forward bulkhead before running down the left side?
Curious.
#39 DavidLayton
DavidLayton
  • 35 posts
Posted 27 January 2019 - 10:46
I have acquired a Honda Collection 1 book and while it is in Japanese, I can at least make use of the photos.  Attached is one with my notations.  Now I may have misidentified an item, feel free to correct me.  I admit, I do not fully understand the fuel injection system arrangement.  There is a fuel line that runs up the left side frame through the fuel pump and to the metering unit.  I would assume this is the fuel to the metering unit line.  But there is the thick line that goes from the metering unit along the cam cover to the fuel tank.  Is this going in or is it a recovery line?
Brabham-BT-18-Honda-Collection-1-Engine-
Edited by DavidLayton, 27 January 2019 - 17:50.
#40 Ray Bell
  • 82,315 posts
Posted 27 January 2019 - 10:52
How about you post the photo here so we can see it?
Maybe with more looking at it we'll get an answer...
#41 DavidLayton
DavidLayton
  • 35 posts
Posted 27 January 2019 - 17:51
Ray,
Thanks you forced me to figure out the URL posting technique.
#42 cooper997
cooper997
  • 4,213 posts
Posted 27 January 2019 - 22:08
From the David McKinney 'Small Cars - Big Opportunities' 1964 - 66 F2 feature in the Graham Gauld-edited 'Historic Racing' Volume 2 issue 2 (final issue).
#43 DavidLayton
DavidLayton
  • 35 posts
Posted 28 January 2019 - 04:39
Both of these photos are of the RA300 engine in the 1965 BT16 chassis.  The 1966 engine was totally different and not canted.  It is interesting to note how much improvement was made between the RA300 and the RA302E, especially considering that the 1966 engine would only have a year's serviceable life.  Quite  an R&D project.  Thanks!
#44 raceannouncer2003
raceannouncer2003
  • 2,944 posts
Posted 29 January 2019 - 07:26
Here's a link to a model:
http://www.modelcars...mula-2-brabham/
Vince H.
#45 DavidLayton
DavidLayton
  • 35 posts
Posted 31 January 2019 - 00:27
Vince,
That is the kit and it is large enough to call out for the fluid lines to be added.  Unfortunately, the modeler was not familiar with the car.  The hydraulics were metal lines going to fittings on the ends of the frame with the black rubber covered lines to the calipers.  The rear brake line fittings would be on the last frame with a T Junction on the left side lower frame on the line to the master cylinder.  If you look a few frames up, you will see a photo of the car in the museum and the notes showing the metal brake lines.  The flexible lines fastened at the frame and ran out the suspension in typical fashion and were not lashed to the A-arms.  The front were near the rear upper A arm.  The lines from the oil filter on that model were going to the injectors.  There were two oil lines from the filter to the motor. (shadowed in orange)  See Photo.  The injection lines would go back to the metering unit.  There is also a fuel pump that is incorrectly located on the model in the vertical.  Contemporary photos show it on the angle with the line going up to the metering unit. (Pink line) My last unanswered question on that is where the oil filter lines go into the motor.  The lines to the oil tank in front are on the right side of the block.    There is not a good picture of the left side of the block.BT18-Honda-Oil-Filter-Fuel-Pump-With-Not
Edited by DavidLayton, 31 January 2019 - 01:42.
#46 DavidLayton
DavidLayton
  • 35 posts
Posted 12 February 2019 - 03:13
With help from Rob Shanahan, I have the answers to the two unsolved issues on the Honda RA302E motor.  Rob confirmed that the Honda's fuel injection was patterned off of the Lucas unit on the SCA and that the thick line channeling along the (driver's) left cam cover is a fuel return line to the tank.  The 2 oil lines go from the remote Oil Filter on the Frame to the original location for the oil filter on the block.  The placement of the motor in the Brabham's frame required the use of the remote filter.  The location is where the red circle is on the drawing.  I am very grateful to Rob and Kevin Whittle whose issues of One Litre F2 were very helpful to me.  I would also recommend the French Auto Diva site for the 1 litre F2 cars and early F3 cars!DSCN1444-w-circles.jpg
Edited by DavidLayton, 12 February 2019 - 22:50.
#47 PZR
PZR
  • 145 posts
Posted 12 February 2019 - 07:45
I am very grateful to Rob and Kevin Whittle whose issues of One Litre F2 where very helpful to me.  I would also recommend the French Auto Diva site for the 1 litre F2 cars and early F3 cars!
Thousands at his bidding speed
And post o'er land and ocean without rest:
They also serve who only stand and wait.
#48 plasticmodeler
plasticmodeler
  • 1 posts
Posted 07 September 2020 - 13:22
I have a quick question..on the RE302E engined Brabham BT18...where does the oil pressure line to the gauge go to on the engine?
