Thank you Henk,
Do you recall what source you used to build your database?
I am trying to establish period reports/documents as to the engine size...
Best
Elad
Hello Elad,
That would be a long story. I started collecting data in the early Seventies, more than half a century ago. It has never been a "single source" action, I have tried to use as many sources as possible, which sometimes forced me to classify some sources as "less reliable".
At first, everything was written down in copybooks, but fortunately Microsoft introduced MS-Access in the early Eighties, and that has been my workhorse ever since.
I started out with magazines (current races), then also magazines with interest in history, after that came books (I now have more than 1500 in the house, don't tell my wife). And after that came websites. I have now reached the point that more information becomes available than I can handle.
One of the consequences here is that some sources contradict each other. So the databases I set up (26 in total) contain a field "Alt" for each entry, where I keep track of other chassis numbers or engines than are the truth accepted by me (at the time of entering the data). It does occur that I have to switch chassis numbers from Chassis to Alt and vice-versa, and the same for engines. Rare are the cases where undeniable proof is given, so this is more or less a personal fingerprint. That's why. when I quote from my DB, I also try to include the Alt field if there is info available there.
I hope this helps, but I think that some doubt will remain.
Kind Regards,
Henk Vasmel
