Why do electric cars have 12V battery?
18 replies to this topic
#1 Hati
Hati
  • 8,820 posts
Posted 19 July 2025 - 13:27
Yes, because they do have 12V equipment, but why they do that with battery and not transformer/PSU that generates 12V from drive battery? Apparently the 12V battery is a big source for problems in electric cars so why is it needed? Would the required PSU be too big or why they keep the traditional battery onboard?
Edited by Hati, 19 July 2025 - 13:28.
#2 BRG
  • 28,894 posts
Posted 19 July 2025 - 14:52
Good question. The 12v battery is charged from the drive battery pack anyway, so there must be some other reason for retaining that battery.  As you say, if it gets flat or fails, you can have real problems, especially on Teslas where you cannot even open the doors!   Hopefully other EV cars don't have the same issue
Edited by BRG, 19 July 2025 - 14:52.
#3 MichaelHickey
MichaelHickey
  • 7,051 posts
Posted 20 July 2025 - 01:52
The 12V battery circuit is used to disconnect and reconnect the main high voltage drive battery when you park. That would be the main sticking point.
#4 MikeTekRacing
MikeTekRacing
  • 19,136 posts
Posted 22 July 2025 - 23:24
That is not true. You can open the doors mechanically
#5 Greg Locock
  • 6,552 posts
Posted 23 July 2025 - 01:53
...assuming you've read the owner's manual
#6 MichaelHickey
MichaelHickey
  • 7,051 posts
Posted 23 July 2025 - 06:03
The owners manual is conveniently located on the vehicle's touchscreen. (provided the 12V battery isn't flat)
#7 Greg Locock
  • 6,552 posts
Posted 23 July 2025 - 09:10
An exceedingly good joke, in context. I suppose the serious answer in context is that you google it as the water rises around the lifeless hulk of yourTesla that you just drove into a river.
#8 BRG
  • 28,894 posts
Posted 23 July 2025 - 09:13
Well, I have no direct personal experience of this but based my comment on this video.
https://www.youtube.com/watch?v=ePIQaruQX4Y
#9 just me again
just me again
  • 7,740 posts
Posted 23 July 2025 - 10:10
I can get out of my Tesla with mechanical handles. Using them with no 12v power might damage the doors, because the windows have to go 2cm down before opening!
I have no idea how to get into my Tesla if the 12v battery is flat!!!!
#10 Magoo
  • 3,874 posts
Posted 24 July 2025 - 22:11
Great point. On the Model Y, the emergency manual release for the rear doors is hidden behind a popout panel in the door card. Not terribly handy when the vehicle is on fire.
My Model 3 had manual releases for the front doors that were totally accessible and intuitive. In fact it was easy to use them by mistake instead of the electric buttons.
However, there were no manual releases at all for the rear doors, which is insensible.
The whole idea of including both manual and electric door releases flies in the face of Musk's Chapman-esque principle, "the best part is no part."
If you need manual door releases in any case, what is the purpose of electric releases? Dumb. Get rid of them.
#11 Magoo
  • 3,874 posts
Posted 24 July 2025 - 22:15
You have to get into the frunk (see manual) and jump or replace the 12V battery.
#12 Magoo
  • 3,874 posts
Posted 24 July 2025 - 22:19
I used the manual door release by accident more than a few times and it didn't hurt anything. I think habitual use would probably damage the roof rail weathstrip.
#13 MikeTekRacing
MikeTekRacing
  • 19,136 posts
Posted 25 July 2025 - 18:42
some edits: i read the replies better
That's being locked out, not locked in. I thought you meant locked in. My fault :)
you can't be locked in, there are mechanical releases on the handle inside.
Locked out, yes, without any battery you have some work- for the Y I have to remove the tow cap I think and plug 12V there - it will pop up the frunk and give me access to the 12V battery.
Edited by MikeTekRacing, 25 July 2025 - 18:45.
#14 Lee Nicolle
  • 11,330 posts
Posted 19 August 2025 - 01:47
And have a convenient torch to find the release
#15 echealth
echealth
  • 10 posts
Posted 25 February 2026 - 11:12
They still use a 12V battery because the car needs a low voltage system that works even when the high voltage pack is shut down. The main traction battery is isolated by contactors for safety whenever the car is off, in a crash, or if there’s a fault, so you need an independent source to power computers, locks, airbags, lights, and to boot the system so it can even connect the big battery.
There is a DC to DC converter that steps the main pack down to 12V while the car is running, but without the small battery there would be no way to wake the car up in the first place. It’s basically the same logic as a traditional car needing a starter battery, just without the starter motor. It also provides a stable buffer for sensitive electronics, handles transients better than a pure power supply, and keeps legacy automotive components compatible, which is cheaper and proven.
#16 echealth
echealth
  • 10 posts
Posted 12 March 2026 - 12:24
A 12V battery is kept mostly for reliability and safety, nu doar din obișnuință. Almost all car electronics, lights, locks, airbags, ECUs, sensors, infotainment run on 12V because the whole auto industry standardized around that decades ago. You could power everything directly from the high voltage pack through a DC to DC converter, and in fact EVs already do that while driving, but the small 12V battery acts like a buffer and backup.
If the high voltage system shuts down after a fault, accident, or maintenance state, the car still needs a low voltage source to wake computers, unlock doors, power safety systems, chestii de bază. Without that battery the car could become completely dead, gen nu poți nici să pornești sistemul ca să activezi contactors for the main pack. So yeah, it adds another failure point, ai dreptate acolo, but from an engineering standpoint it is a cheap and simple redundancy layer instead of redesigning every automotive component to run directly from hundreds of volts.
#17 gruntguru
  • 7,765 posts
Posted 16 March 2026 - 08:38
You're not a confused bilingual bot by any chance @echealth?
#18 Michael Ferner
Michael Ferner
  • 7,559 posts
Posted 19 March 2026 - 10:37
Shhh! You're not supposed to arouse feelings of awareness in robots, this can lead to severe post-traumatic digital stress disorder!! The poor thing will get its ones and zeros in a knot...
#19 Greg Locock
  • 6,552 posts
Posted 19 March 2026 - 23:34
I'm guessing AI translation from Romanian, but the site I just poked had no problems with the couple of untranslated phrases.
