This doesn't sound believable to me. How would they know what other engine designers have done without industrial espionage?
The Race is running the story as well.
The trick at centre of 2026 F1 engine loophole controversy - The Race
An FIA spokesperson told The Race: “The regulations clearly define the maximum compression ratio and the method for measuring it, which is based on static conditions at ambient temperature. This procedure has remained unchanged despite the reduction in the permitted ratio for 2026.”
However, the issue may have cropped up ahead of 2026 because manufacturers have realised, amid the change of characteristics with the 2026 regulations, that there are grounds to seek advantage from chasing a higher compression ratio than what is laid down in the rules.
And while it is well known that thermal expansion of engine components is a natural phenomenon, there is no measurement laid down in the rules that dictates what is an acceptable level for this to happen.
The FIA has suggested that procedures could be changed, or even the regulations revised, if the matter blows up in the early stages of the season.
The FIA spokesperson added: “It’s true that thermal expansion can influence dimensions at operating temperature, but the current rules do not currently require measurement under hot conditions. That said, the topic has been and is still being discussed within technical forums with the PUMs, as the new limit naturally raises questions about interpretation and compliance. The FIA continuously reviews such matters to ensure fairness and clarity, and if necessary, adjustments to the regulations or measurement procedures can be considered for the future.”
