In the partial photo linked (Motor Sport online collection, British GP, July 76), I've circled some sensor connectors. https://cdn01.hobbyp...ost.com?eulrobp
In foreground left, the water/fluid (just plain water?) temperature sensor. In the background there seem to be two tubes - attached both on the left and right - on each radiator. I think the one on top one is the water pressure tube.`
Apparently the McLaren M23 had two temp and pressure gauges, each monitoring 4 cylinders left and right. As far as I can see from instrument panel pics, the P34 arrangement was not the same. One dual gauge was oil, the other water.
Here's where I'd appreciate some help:
1) If so, why have pressure tubes on both the left and right water radiators? And if there are pressure tubes left and right how was pressure measured?
2) If my info about the M23 is correct, with only two gauges how did McLaren handle oil temp and pressure?
3) Can anyone tell me where the oil temp and pressure sensors for P34 located on the oil coolers? Oil temp possibly front end of oil cooler (away from viewer in this picture)
Thank you,
Mark
Edited by addled, 04 March 2026 - 10:04.
