1934 Baker Axleflex Front Suspension
6 replies to this topic
#1 Bob Riebe
Bob Riebe
  • 3,344 posts
Posted 13 August 2026 - 16:35
              https://macsmotorcitygarage.com/swing-and-a-miss-1934-baker-axleflex-front-suspension/
               1934-Hudson-Axleflex-600x360-1.png?w=600
#2 Greg Locock
  • 6,552 posts
Posted 13 August 2026 - 21:47
Leaf springs on a beam axle provide some (only a little) antiroll stiffness, that's what the clips are there for. The short arm length of the axleflex magnifies the effect.
I suspect one reason this got dumped is that it has very high camber in roll (even compared with a beam axle). This causes a gyroscopically generated force in the tie rod, it means when you drive over a one wheel bump or pothole your arms get ripped off.
This was one of the main drivers for IFS rather than beam axles. Camber induced gyroscopic effects are  mentioned in one of the old school vehicle dynamics books, Bastow.
Edited by Greg Locock, 14 August 2026 - 00:59.
#3 MatsNorway
  • 2,867 posts
Posted 14 August 2026 - 08:13
Really? is it that severe/important? Any idea of what kind of numbers we are looking at?
#4 Greg Locock
  • 6,552 posts
Posted 14 August 2026 - 22:16
Several Nm at the steering wheel. Any more than 10 needs a very big steering wheel, we aim for 6 or so.
#5 Greg Locock
  • 6,552 posts
Posted 15 August 2026 - 00:15
Steering ratio say 6 turns lock to lock for 1/4 turn steering, 24:1
Polar moment of inertia is say 1.5 kg m^2
wheel rotational velocity at 30 mph is 5*2*pi=30 rad/s
camber change = vertical wheel velocity/swing arm length. vz_max is 2 m/s take 1/4 of that =0.5 m/s SAL looks to be 0.4, camber change =1.2 rad/s
Hence kingpin torque=1.5*30*1.2=50 Nm. There are two wheels, double that and divide by the steering ratio SWT=4 Nm
That is a bit low maybe my 1/4 for vz is optimistic.
#6 mariner
  • 2,460 posts
Posted 23 August 2026 - 07:49
Greg , as side question is Barstow still considered relevant for the basics ? When Milliken etc had yet to be published it was my late night reading ( very sad) ?
My old favourite was actualy in Campbell " new directions in suspension design - the Professor Guest double conjugate points solution ! As a graphical not maths sort of guy I spent many long hours folowing the grahical solution - I THINK I got it in the end
Edited by mariner, 23 August 2026 - 08:04.
#7 Greg Locock
  • 6,552 posts
Posted 23 August 2026 - 10:19
Milliken is not the be all and end all. Very  much biased towards circuit cars. I'll happily read up on thoughts of old geezers, and still watch as young geezers (like Erik) take a car with a theoretically stuffed F/R ride frequencies 1:1, and make a decent ride by messing about with shock tuning. That ain't in a book.
