Big N/A Power With A Jeep Straight-Six
No replies to this topic
#1 Bob Riebe
Bob Riebe
  • 3,344 posts
Posted 15 October 2026 - 18:05
       newcomer-racing-goes-for-big-n-a-power-w
       https://www.enginela... 10/9/26 (Copy)
       The first dyno pulls we made were with a Holley 850 cfm carburetor.
       The fuel-injected setup uses a 75 mm throttle body that is 5 mm larger than stock for additional flow.
      We found that the peak numbers for the carbureted and EFI setups were virtually the same, but the EFI setup smoothed out the torque curve and removed dips that were there when running the carb. So, efforts continued to improve power, concentrating solely on EFI. Newcomer also tested different valvesprings as well as two sets of full-roller rocker arms (1.7:1 and 1.8:1 rocker ratios) to see how they affected the power curve.
      By the end of the day, Newcomer had the naturally aspirated stroker straight-six up to an astounding 424.2 lb-ft of torque at 4,700 rpm and 434.1 horsepower at 5,800 rpm. Now, if you are used to dealing with V8’s like the LS or boosted engines, this may not seem too impressive. But when you consider that the best the stock four-liter straight-six could produce over decades of production was 240 lb-ft of torque and 190 horsepower, that picture changes drastically. We say upping the torque by 184 and the horsepower by an astounding 244 is quite an achievement.
Edited by Bob Riebe, 15 October 2026 - 18:07.
