Late Model Engines Turns a 445 into a 460-Cube Brawler
No replies to this topic
#1 Bob Riebe
Bob Riebe
  • 3,344 posts
Posted 15 October 2026 - 18:30
            https://www.enginelabs.com/engine-tech/engine-buildup/late-model-engines-turns-bosszilla-into-a-460-cube-brawler/
            Bosszilla’s cylinder heads are the same cylinder heads as in the previous article.
            They are stock castings with lightly ported factory intake and exhaust ports.
            We’ve done several installments on our Project Bosszilla buildup with our friends at Late Model Engines,
            and now it’s time to get serious and make some real power.
           And to do that LME  added over an eighth-inch of stroke to bump this engine up to a beefy 460 cubic inches.
     That 460 number is the headline with a nod to Ford’s big-block engine history, but the details matter more. Bosszilla is built around a 4.225-inch bore and a 4.125-inch stroke. For reference, in stock form, the engine comes with a 4.22-inch bore and 3.98-inch stroke. The bore increase is practically negligible at only five thousandths of an inch, which tells you immediately what the goal is. This isn’t about pushing the cylinder walls to the edge. It’s about adding displacement without compromising the foundation.
     That’s an important detail. It keeps cylinder wall-thickness nice and beefy to handle the extra side loading created by extra stroke and avoids introducing unnecessary risk. Instead, the extra displacement comes from stroke, which is where things get interesting.
     But while Bosszilla stopped at 4.125 inches, that’s not a limit for Late Model Engines when it comes to the Godzilla. Their program extends out to 4.375-inch and even 4.500-inch stroke combinations, landing the engine into 491 and 505 cubic inch territory.
Old-School Upgrades On A New-School Engine
     Ford performance enthusiasts have had the overhead-cam Coyote for years, but they’re salivating over the potential of the Godzilla package for one main reason. Swaps.
The Coyote is a highly efficient engine that can make great power, but its dual-overhead camshaft valvetrain makes the engine quite wide up top. Meanwhile, the Godzilla is cam-in-block, so even though it has more cubic inches, the outside dimensions are quite a bit more compact. That means it can actually be a lot easier to swap into an old Mustang or Fairlane without cutting up the strut or shock towers.
Edited by Bob Riebe, 15 October 2026 - 18:33.
